ALL my knives are JDM TYTE YO
Had a mate that worked in a knife shop and became really obsessed with people's knives in kitchens.
We're at a house party before we went out once and he couldn't stop commenting on the quality of knives that our mate...
Yeah, cool story ey.
One of my mates friends bought himself a set of knives that were pretty nice, nothing jap amazing though....
Now every time he invites himself around to something at one of our places, he picks up a knife in the kitchen and tells us how much better his ones are. Makes me want to grab the crap knives from his hand and stab him in the stomach just to prove that they are sharp enough.
/end knife elitist rant
What's the best stuff to spray on my rear bar to keep off exhaust discolouration? Is there anything that can seal the paint so I just have to wipe it off?
Currently it kinda just goes straight into my wax and I fully need to Wax and Grease Remover + Clay or Orbital polisher to get it off properly.... :angry:
Is there a product that makes life easier for me?
Try silicone spray
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
