I know its a few pages back
But how is his surname actually spelt,
Pettet
Pettite
Pettit
Can we get a poll going on ? cause everyones doing it differently. Also has he got a wife? cause i know of a pettit somewhere in southeast. :P
Pettett if I remember correctly from the defect label, I'll look later.
Ive been knox a handful of times in my r34, never had any trouble... yet
I drive past there 5 times a week and have only had trouble once. But it does happen; just a numbers game and the wrong time of day.
my brothers now 340rwkw (on trents hub dyno at least..) car still cant pull on me, dat dere turbo lag vs supercharger
can we quit this faggotry about hub dyno's reading higher please? i'm soooo over it! they are better and more accurate... it's one dude in adelaide that bullshits his figures and happens to have a hub.
trent's dyno is callibrated correctly and runs the appropriate correction mode.
cars on trent's dyno make the same power as on a dyno dynamics in shoot 6 mode
my car was within 10kw of 2 different dyno dynamics rollers
Pettet
Pettite
Pettit
easy...
F A G G O T
easy...
F A G G O T
Hub dynos are better as you eliminate variables in the tuning (tyre pressure & slip at the wheels) makes it possible to repeat runs and have results the same. Good for fine tuning as you don't have unknown variables messing with each run.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
