at least chatruese doesnt burn... pure alcohol? itd be like metho with delayed vomiting.
when in NZ a bartender offered me his 'under the counter' bottle of absinthe. said it was 85%. had a shot and 5 seconds later my stomach was like nup. walked to the toilet casually and vomited it all up.
http://gizmodo.com/5984476/meteorite-crashes-in-russia-panic-spreads
Fuarkkk
"What's more incredible: unconfirmed reports say that an air defense unit fired a missile as the meteor entered Russian airspace at supersonic speeds, shattering it to pieces."
Thats fkn mad. What happened if that shit happened to aus. Dont think we got no air defence units. Hahhaa.
f**ken just went to renew my passport as the old one full.
So frequent traveler passport with priority processing.
there goes $500 WTF
Bill it to work. If you can't afford passport, they can't send you overseas lol
company policy is that they don't refund passport
same as eg Aaron not refunded for drivers lic
am pushing for an exception tho
Lol so tell them you can only afford the standard rate. If they want priority they pay haha
http://gizmodo.com/5...a-panic-spreads
Fuarkkk
yeah i just watched all these videos of that.. pretty amazing!
didn't know they fired a missile at it! but I'm guessing there is no way a missile could of even caught it..
if it did.. wow.
lol in aus our air defense is just to throw other rocks at it
if it did.. wow.
Can't find a google image, but I am reminded of the Simpsons episode where the Australians throw cans of beer at the helicopter...and a throwing stick.
that throwing stick stunt of yours has boomeranged on us!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
