muzzas fuckin love jetskis. fact.
also... took the new golf to the VW specialist to give it a once over and full service before roadworthy tomorrow. park in front of the place, jump out walk into the shop to hand over my keys. Old dude wanting a second opinion on a 17k bill VW charged for an engine replacement in his Touareg is being served, so I wait patiently. Old dude finishes up, walks out. I start chatting to mechanic. Old dude walks backs in and goes "sorry mate, I just backed into your car".
FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
So apparently my housemate's girlfriend is angry because i told her that my cast iron wok needs to be dried after washing or it'll rust. Sif not dry cooking stuff after washing anyway.
apparently its the condescending way i said it. lol.
and she wants to move out.
I thought that was common knowledge?
After I wash ours I dry it then put it back on the heat for a few seconds while rubbing fresh oil around it with paper towel...
HEI! HEI!!! You driiiii tha wok!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
