My skyline is 2ltrs :(
Might give it a miss on the ethanol tune. Will get a pulp tune first so then I will have 2maps to switch between.
that's cute
nah but seriously waiting for yella terra to release their intercooler kit for mine, then add some e85, injectors and fuel pump and run a smaller pulley come at me ~500rwkw all in good time..
Edited by UNR33L
Got a call from manager and their photo showed up whilst ringing. Found that odd as I didn't add any photo?
Turns out Facebook detected their mobile number and my iPhone showed their display pic. Also to add that I don't have them added on fb either.
So that means a long as you have someone's mobile number, you can find their Facebook profile automatically O_o
only if they've got the number displayed on facebook I guess
Edited by UNR33L
What's the craziest engine conversion someone has done in an Evo?
WRC spac tune bro.
There's surely no way around that!
Amateur
you want your helmet or not you roid raging dropkick?
glasses are annoying, wake up, can barely see clock / find your phone, have to take them off at the beach / swimming cant look at womens or see mates / throw balls n shit, have to clean them all the time, can't play footy, can't wear sunnies, look like an idiot at 3d movies, can't see shit on roller coasters with no glasses, fog up in shower or heat, can fall off during sex, annoying to get motorbike helmet on, can't take semen to the face, have to get special wider goggles when I was doing motorcross the list goes on, can't motorboat things
Contact Lenses :)
wat?
Cos train line?
I meant just in general, but I suppose that would have an affect on it too...Personally I don't want the fkin thing anywhere near my house, but if it means some flog will pay me more for it one day, I'll deal with it
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
