damn that sucks..
I get pissed off paying 4$ parking at doncaster westfield..
I normally park in public area and move my car every 3 hours.. though today security finally caught on and told me to park in staff carpark.. thought i cant cos too low =/
so prob just cop an extra few $ and leave it in customer parking instead.
I've never been told to do this in whole 2 1/2 years of working there...
Could be the fact they can't keep up with the amount of cars I had :P
Staff parking is $4 all day if I recall.
when I used to run Hard Kandy (99-03) we had an office above the club in russel st.
I was there 3-6 days a week depending on what we had going on...and used to park in alleyways the whole time.
I got fined like once every month. MAX
saved me thousands
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
