If Judge Judy has taught me anything, its that stupid people somemtimes do stupid things with some kind of backstory.
Cousins aunties step-brothers mothers dog probably borrowed money a while back, or stepped on someones shoe or called someone a slag.
Anyway point is, if there was some sort of personal involvement or the victim recognised them from kindergarten or if it was some sort of vigilantism (sp) the news/police report isnt going to mention it.
Forced break-in of elderly lady? sure, probably pretty straight forward.
Man stabbed in a supposed mugging and the muggers not taking anything and then being caught within 24 hours? theres probably more to this.
This is a good point...
When a relative of mine was jailed, I couldn't believe how many media reports came out spruiking absolute bullshit - facts and statistics wrong; writing only one side of the story; changing words around to suit; misquoting etc. Completely lost faith in the mainstream media at that point. Focus seems to be on getting the story out there and grabbing attention rather than telling it how it is. Sensationalism defined.
Can do, are you gonna be running an aftermarket oil cooler though? If you are it might pay to delete the factory heat exchanger while the engine is out. NA heater hoses clean it up a lot under the plenum and gets rid of a heap of potential leak points.
So I see, no aftermarket oil cooler yet unfortunately :(
Where did you get that pic from? One of your jobs? Looks very less cluttered than my stock one
@@Birds
when we had a shooting near the club, the herald sun ran a FRONT PAGE article saying the shooting happened inside Hard Kandy. They included our name, logo, a photo of people on the dancefloor and a floor plan of the clubthat was complete with little stars showing where shots were fired and where the fight broke out.
the shooting was unrelated to HK and actually happened at the exford which is on the other side of the road and has nothing to du with HK. It also happened over 30 minutes after we kicked the group out of our club for being overly drunk and abusive.
still the herald sun just made up a headline grabbing story and there was nothing we could do as once the paper was run, the damage was done.
we contacted our lawyers (a HUGE international firm) and were told that there is no point pursuing it as the herald sun make a habit of doing this and has the means and finances to defend the issue for a lot longer than we do
cliffs notes: herald sun has no integrity and I would like release a pack of ebola monkeys into the building and lock the doors / windows
Here's the part #'s for R34 heater hoses, rad hoses, thermostat & heater core.
Upper Rad Hose - 21501-AA000
Lower Rad Hose - 21503-AA000
Heater Hose Core Upper - 92401-AA000
Heater Hose Core Lower - 92410-AA000
Metal heater hose piece on firewall - 92403-AA000
Heater hose upper - 92400-AA500
Heater hose lower - 92412-AA500
All The Hoses for the heat exchanger
14056-21U20
14053-21U10
14056-21U10
21307-21U20
21307-21U15
Thermostat - 21200-V7205
Heater Core assembly - 27140-15U00
If you have the opportunity to do an aftermarket oil cooler it would save a bunch of effort and be better for your engine in the long run, These are the parts needed for heat exchanger delete which then get rid of the upper and lower heater hoses and all the heat exchanger hoses as well.
Fitting between pressure sender and block - 25071-F6000
Front Heater hose - 92412-70T00
Rear heater hose - 92400-70T00
Threaded piece for oil filter - 15213-21001
Block fitting for Rear heater hose - 14075-75T00
@@Birds
All of them have no integrity as far as I'm concerned. The moment something becomes more about ratings and money than truth, corruption has a path. There's more to everything, which is why we're never in a good position to judge based on news alone. Even experts disagree!
A friend of mine did work experience and confirmed what we already knew: working for the herals sun requires selling your soul.
And unfortunately, I work with people who read the shit. I do know poeple who read it, just so they can point out all the errors and how misleading the stories are, which is almost just as bad.
Offloading responsibility onto others is quite possibly the best way to get through life without a hitch. I believe they teach courses on it, but they call it a diploma of management.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
