GTR Shafts don't fit in GTST hubs.
The Drive shafts on my car (A-LSD GTST) were 30mm splined 5 bolt shafts
The new Diff has 6 bolt half shafts, so I decided to use the GTR Shafts that I got with the diff, but then discovered that GTR Shafts have 32mm splines.
So I pinched the 32GTR Hubs from Matt Borci's 32R rolling shell and swapped them into my knuckles...
Like a glove... ? Definite learning experience :P Now I just need to get my ABS working again and I'll be very happy :)
Whats the must have accessory for the gopro3? LCD screen or battery pack? Or neither.
what you want to use it for.
if your need long life the battery pack is good.
LCD is useless for the 3, just use the app and use your phone as view finder.
spend extra money on attachments and mounts and such.
LCD is a godsend for the GoPro 1.
never fit on the GoPro 1 HD2 had the expansion port, I've now got the wifi backpac for it and that better than the LCD as you can control it from in the car with it.
3 has it built in so even better
Happy birthday birds!
Fark celebrity apprentice hasn't started and yet I despise it already not to mention the lack of celebrities - dawn Fraser sure the rest have about as much profile as roadkill
i was thinking the same thing, at least the u.s version is alright.
I have the HD hero and it fits; pretty sure it's a GoPro 1
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
