GTR Shafts don't fit in GTST hubs.
The Drive shafts on my car (A-LSD GTST) were 30mm splined 5 bolt shafts
The new Diff has 6 bolt half shafts, so I decided to use the GTR Shafts that I got with the diff, but then discovered that GTR Shafts have 32mm splines.
So I pinched the 32GTR Hubs from Matt Borci's 32R rolling shell and swapped them into my knuckles...
Like a glove... ? Definite learning experience :P Now I just need to get my ABS working again and I'll be very happy :)
Whats the must have accessory for the gopro3? LCD screen or battery pack? Or neither.
what you want to use it for.
if your need long life the battery pack is good.
LCD is useless for the 3, just use the app and use your phone as view finder.
spend extra money on attachments and mounts and such.
LCD is a godsend for the GoPro 1.
never fit on the GoPro 1 HD2 had the expansion port, I've now got the wifi backpac for it and that better than the LCD as you can control it from in the car with it.
3 has it built in so even better
Happy birthday birds!
Fark celebrity apprentice hasn't started and yet I despise it already not to mention the lack of celebrities - dawn Fraser sure the rest have about as much profile as roadkill
i was thinking the same thing, at least the u.s version is alright.
I have the HD hero and it fits; pretty sure it's a GoPro 1
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
