Hamish: haven't tried any others since mr burger. Paulie is a cousin or something lol..don't know him but I've probably met him, my extended family is massive. Any dessmann in Australia spelt that way is a relative
Didn't know he was the chef at parlour though, which is on the list of joints to hit
lol... I worked with him for a while a few years back.. funny dude
Audi's are aiight
I drove an A5 a year or so ago. And drove the A4 on the SAU cruise last weekend
For what driving I do around town etc its great cruiser sits on 1200rpm everywhere really smooth but goes good if you want it to
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
