gym to get fit... it's not a dick measuring contest. fk weights
Weights will get you fit too... In tandem probably best bet imo. Unless you just want mad endurance or something :S
I dont see why the government needs to throw cash to try and keep a failing company afloat. The industry has had many years warning to shape-up and change and they have done too litle too late. Territory was successful, but need some serious movers and shakers by that point. They played it 'safe' and now theyre bust. I do feel for the employees though, government money should go towards them and not ford (if there was an option and government were gonna splash the cash anyway)
My reasoning is 2 fold...
1) I give no farks for weights or impressing people with what I can lift
2) I have fkd knees and left elbow, so i'm pretty restricted on what i can lift.
I might do some core stuff eventually, but really I just want to get fit
Well said.
At least the employees have a decent amount of time to secure new employment in this instance.
ford shutting down production in aus.. if government gave them as much as they did holden that may not happen..
If they made decent (smaller) cars for a reasonable price that people liked the look of, they wouldn't be going under.
Toyota can't make enough FT86's... Styling must be the key. I doubt other manufacturers will learn from Ford's mistakes though.
Ghost camera wont arrive before sandown... delays due to tornado. Forcast is slightly improving for weekend... itching for some track action. Passenger bucket seat is almost ready :)
..work...going...too...slow...
Had a photoshoot.
Strength training makes you fit and shreds fat.
Ford Australia going under has more to do with local product struggling to compete against conglomerate manufacturers in other countries employing people to work for SFA and...in the grand scheme of things...the mentality behind you buying your shit from "eBay anywhere but Australia" because it's the cheapest you can get it.
In saying that I'll be having macca's for lunch
I had a Chicken Schnitzel Sandwich, with Cheese, and ham, and tomato relish....
Ok, so it was pretty much a parma sandwich. I'm alright with this.
Been to Schnitz at Knox? They do this!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
