I bought a Asus transformer for uni last semester. Shouldn't have.
Zenbooks look the goods. But waiting to see some more Haswell ultrabooks come out before deciding. Touch screens seem nice for W8.
MBP is actually pretty good hardware for your $ (especially if student discount + sale, and I believe you can just upgrade ssd and ram yourself with little difficulty). Depends if you ceebs with the OS though. Trackpad etc is very good, too.
Samsung Series 7, 9 etc do look pretty good as well iirc.
If you want to use on the move get a 13 inch ultra book
Personally I'm looking to move to a Samsung ultra book myself
If you need more power/ screen than an ultra book at home get a tablet and a home system separate
And no idea why ppl think I travel much!!!!!
Hybrid tablet/laptop worth getting or more of a gimmick?
hmmm.... you guys think I'll be fine with stock breaks? 1 hard lap then 1 cool down lap in each run?
Think I might stick to deca this year before a tune and brake upgrade.
Stagea brakes the same, better or worse then the GTT? Also how much heavier is your car then mine
I had DBA slotted rotors and street pads and didn't have an issue. Street pads won't last long though
Also depends on the track, Winton not too brake heavy, where as Sandown is.
Dell make good shit and their customer service is awesome. Mine came with a slight scratch on the screen so they sent me a whole new package within a couple of days. Laptop has lasted me nearly 7 years now without a hitch, would def buy again. Even their desktops aren't a huge deal more than getting and building the parts yourself.
  • Like 1
I used my laptop for gaming cause I specced the bugger out. That was back before laptops were known for gaming and a lot of CS players were surprised that someone was beating them from a Dell haha
My laptops a Dell XPS 15 L501x, specced it pretty decent a couple of years back so it's still half decent.
Core i7 Q740
6gb ram
Geforce GT435M 2gb
640gb hdd
1920x1080 screen
Found a 20% discount voucher online which got me Win7 Ultimate & extended warranty while keeping under budget ($1700)
Dells warranty and customer service is good but you're really best off getting an extended warranty. Have had 3 hard drives die on me, the current one they swapped from Western Digital to Toshiba though and it's still going strong. Also had the the power plug break on me a bunch of times, this is due to shitty design as it's only held on by 1 small screw attached to it by a small weak mounting point. Battery only just lasted longer than the 1 year battery warranty too :/. Apart from that though it's been pretty good. Dell parts are cheap & readily accessible(3rd party) after warranty runs out too.
ASUS G75VX
CPU: Intel 3rd Gen. i7 3630QM 2.4GHz (Turbo 3.4GHz)
OS: Windows 8 64bit
RAM: 32GB DDR3
HDD: 256GB SSD + 1TB SATA
Graphic:Nvidia GTX 670MX
3GB GDDR5 VRAM Dedicated VGA
Screen: 17.3”FHD LED Screen(1920x1080)
UBB3.0 * HD Webcam* WiFi N * Blu-Ray Writer * DisplayPort * HDMI * Bluetooth
Awww yeah
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
