ASUS G75VX
CPU: Intel 3rd Gen. i7 3630QM 2.4GHz (Turbo 3.4GHz)
OS: Windows 8 64bit
RAM: 32GB DDR3
HDD: 256GB SSD + 1TB SATA
Graphic:Nvidia GTX 670MX
3GB GDDR5 VRAM Dedicated VGA
Screen: 17.3FHD LED Screen(1920x1080)
UBB3.0 * HD Webcam* WiFi N * Blu-Ray Writer * DisplayPort * HDMI * Bluetooth
Awww yeah
I've just read up that the 4th gen intros came out. With dell Alienware being one of the first laptops to offer it.
Also new nvidia graphics card but that puts it to a price of $2500 :x
Might get the 4th gen intel and compromise on the gfx.
And no idea why ppl think I travel much!!!!!
I've never stepped outside of Australia! Stop complaining you!
Stagea brakes the same, better or worse then the GTT?
The latter..
Stagea brakes are more like na skyline/s13 brakes, single sided twin piston fronts, single piston rears
^ This man knows. :unsure:
Haswell worth it for the battery life for sure, man.
am thinking this one;
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389935#!tab=specs
Intel® Core™ i7-4700MQ (2.4 GHz, 6 MB L3 cache)
NVIDIA GeForce GT 740M (2 GB DDR3 dedicated)
15.6" diagonal Full HD BrightView LED-backlit TouchSmart (1920 x 1080)
Weighs 2.5kg but has haswell, 740M & touch screen for $1000~
or the 17" non touch screen
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389947#!tab=specs
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
