What you buying now?
lol
well i bought some KYO-EI revo neo chro lock nuts from Autotechnik though seems that they dont have any.. waiting for refund now - so instead of waiting a few weeks from rhdjapan im looking to buy them from visionr..
lol
Mr. Moneybags!
What wheel / lock nuts you got on the wheels, at the moment?
anyone bought through http://www.visionr.com.au/ before?
I bought some metal valve caps. Delivery time was ok, I think communication was pretty poor (ie lack of the english skills)
http://www.heraldsun.com.au/news/blackout-in-inner-north-melbourne-suburbs-turns-into-hipstergeddon/story-fni0fiyv-1226676169687
But Hamish would love it.
Rally up the troops Hammy!
Couldn't you have a place as your primary residence on paper whilst living elsewhere?
Depends on the situation
how can i move some of my partners earnings onto my return then...cause i have about 2-3k of tax free money available if i can...
On the basis that your wife is on a Salary & wage
No can do Jeff
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
