He has also stated that in Scott's original, the viewer had trouble working out which characters were robots (replicants) and in his version the viewer "will definately be aware which characters are robots"
You know what that spells right? origin story yayyyy. Dark backstory, add some hatred for replicants with a garnish of disaster porn and you have Blade Runner 2: Apocalypse
Drove my first Porsche (only a cayman) today. Very low to the ground with small windscreen. Cockpit feels very similar to the s2k.
The PDK gearbox was cool, it rev matched on deceleration & gears changed without feeling anything
Handled quite well and suspension was firm. Could only imagine how much fun it would be with a proper engine :P
I did like the engine being behind, did sound nice when I gave it some poke
Still not as good as the R32 right? :P
It's a new day... still mad...
“The original movie was great in the 80s, but try watching it now next to movies like Attack of the Clones and The Last Airbender, and it really does feel lacking by today’s standards.”
When asked about casting, Bay’s keeping tight-lipped for now, although sources inside Hollywood say both Shia Leboeuf and Will Smith are in callbacks for the part of Rick Deckard, while Chris Tucker and Nicholas Cage have both been hinted at for the part of sadistic Replicant, Roy Batty (expected to be renamed: Roy Barry).
Asked how he plans to update the characters: “In the original, the robot characters really didn’t look or act much like robots – due to a lack of CGI options in the 80s. So you really had to use your imagination there. That was the first thing I wanted to address, and while I can’t give much away yet, lets just say you’re gonna know the robots in this movie are robots from the 21st century!”
Michael Bay – whose film credits include such groundbreaking works as Bad Boys (1995), The Island (2005), and Transformers (2007) – is no stranger to the sci-fi genre. He was reportedly first choice of Warner Brothers president, Alan F. Horn, from a shortlist of directors including Ridley Scott, Chris Nolan and Andrei Zvyagintsev.
/RAGEQUIT
hey victorians. thought id ask again... anybody have a pair of 235 40 18's laying around gathering dust? i need a cheep (relatively) pair for my spares...
hell ill take 245's.
please and thank you.
What about soft compound race semis? :)
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
