I remember reading somewhere that there was one of the gates belts which was perhaps a bit noisier than nissan oem?
Also, brahs know what the go is with coilovers and rwc? To my understanding most coilovers are illegal (even raised to legal height) because they don't have 2/3 of the travel required or something along those lines? But in reality, if it's the correct height, are they really adamant on this?
i got the racing belt for that extra peice of mind.....
all height adjustable coilovers are illegal i believe. am i wrong?
Sort of...
There's are some approved coil overs, they need to be able to travel a certain distance in damper or something, they can't be too stiff. And they can't allow the car to go lower than legal limit..
Pedders do Aus legal adjustable coil overs
i bought a gates belt and racepace told me it would be pretty noisy and advised me to stick with a standard belt with HKS cams - might try out the gates though next time as noise wont really bother me that much i guess, just hate in-car squeaks and rattles!
Yup, must have been the Racing belt, then. When I did my major service, I just went with Nissan OEM though :D.
Re: Coilovers, that's pretty much in-line with my understanding, then. However, my question was (even with the new photos etc for RWC) if it's a big issue, provided it's sitting at legal height...
Have the car booked in for alignment etc at Traction tomorrow, but seems a bit of a waste if I'll have to take them out to get RWC anytime soon... that's all...
anybody got any sports store hook ups south east, need some indoor soccer shoes short notice
You dont need shoes
Your the tits brah
is this you Platts when you play soccer?
https://www.facebook.com/photo.php?v=536824339705766
You dont need shoes
Your the tits brah
brilliant! thats me with added fat suit. except fat suit is real. :unsure:
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
