I remember reading somewhere that there was one of the gates belts which was perhaps a bit noisier than nissan oem?
Also, brahs know what the go is with coilovers and rwc? To my understanding most coilovers are illegal (even raised to legal height) because they don't have 2/3 of the travel required or something along those lines? But in reality, if it's the correct height, are they really adamant on this?
i got the racing belt for that extra peice of mind.....
all height adjustable coilovers are illegal i believe. am i wrong?
Sort of...
There's are some approved coil overs, they need to be able to travel a certain distance in damper or something, they can't be too stiff. And they can't allow the car to go lower than legal limit..
Pedders do Aus legal adjustable coil overs
i bought a gates belt and racepace told me it would be pretty noisy and advised me to stick with a standard belt with HKS cams - might try out the gates though next time as noise wont really bother me that much i guess, just hate in-car squeaks and rattles!
Yup, must have been the Racing belt, then. When I did my major service, I just went with Nissan OEM though :D.
Re: Coilovers, that's pretty much in-line with my understanding, then. However, my question was (even with the new photos etc for RWC) if it's a big issue, provided it's sitting at legal height...
Have the car booked in for alignment etc at Traction tomorrow, but seems a bit of a waste if I'll have to take them out to get RWC anytime soon... that's all...
anybody got any sports store hook ups south east, need some indoor soccer shoes short notice
You dont need shoes
Your the tits brah
is this you Platts when you play soccer?
https://www.facebook.com/photo.php?v=536824339705766
You dont need shoes
Your the tits brah
brilliant! thats me with added fat suit. except fat suit is real. :unsure:
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
