That is f**king stupid. How can alleged speeding actions justify an illegal defect???
He has a strong case and is throwin it out
wasn't that myth busted of cant defect car on private property because if it has rego plates on it the car has to comply?
could be wrong but thought that was the case.
Hey guys... Still in hospital with enchiphitis (viral menengitis)
Basically it's an inflammation of your spinal fluid and the fluid around the brain. It keeps expanding and squashes your brain.... Feels like your head is in a vice :/
Neurosurgeon reckons I was just unlucky.
Had a lumbar puncture, something close to 100 blood tests, a couple of MRI's, 6 CAT scans, X-rays, if antibiotics and morphine 4 times daily since Saturday.
Had a seizure on Sunday and didn't know what year it was / couldn't speak properly.
Should be out in a week if all goes well!
shit man thats bad a lady at works husband had this he was farked for about 2 months so hope your good in a week man that'd be a real good result
Either way, rub them the wrong way and your plates will end up in every HWP watch list that exists... They can make your life hell if they want to, so I'd rather not give them a reason to.
Happy birthday top bloke
Cheers nigs!
Happy Birthday
Thank you :D
Happy coming out of vagina day bud.
Well, that's certainly one way to put it :P. Cheers.
did you get yourself any exciting gifts?
;). Stay tuned?
happy birthday hipsterman.
When we do BBH in St Albans... you will find out this is simply not true. Or maybe I'll dress like one to mess with you. *conspiracy music*. Thanks though brah.
Thank god for morphine
Get well soon Mr. Chef.
Happy Bday
Cheers!
How'd you go with ya fog lights
#dontdriveanythingwhileyoung
haha forgot about that! Clearly I was causing grief on prinny hwy for that one :P meh was nothing compared to a defect!
Stuck at work for another half an hour and hungry as fark :(
Edited by UNR33L
either way skyline owner vs cop always going to end up the same way in court
#gothefalconbrah
Have a read of this, maybe best to let this be aye
http://www.trafficlaw.com.au/forum/viewtopic.php?f=11&t=2128
That Hardy guy who runs the forums is a Traffic Lawyer
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
