Yeah I'm already blacked out... Thinking of doing the shiny brassy coloured wastegate actuator as well... Its the only thing that looks out of place atm. Exhaust Mani heat sheild in a matt black heat proof looks baws compared to the rusted old look :D
haha! yea do it.......... almost contemplated doing the inside of the engine bay black too... but that would have been to much. would look good with a white car tho...
Why do you need to carry jerry cans? Unless going long distance there are plenty of United servos around Melbourne.
I'm thinking more for track days/DECA. there's a station walking distance from my place.
Not sure how fuel efficient this pulsar is, battery always gets isolated so never recorded. isn't too bad when off boost.
will get 98 tune, see how turbo handles the motor and if I want more power/boost will go E85 and GTX2871
I also have a scotty intake with a factory AFM and Airbox on the other end of it. cost was about ~250 (for me). Good idea about sticking the rubber to the outside of it for the super paranoid though..
Scotty actually painted mine black, so he's well aware of Vic paranoia
That's because when Scott has nothing better to do, he opens up every single page of SAu and goes through them. It his way of being completely informed
hahahah!
so he desnt have some sort of webcatcher like stao, who knows when ever someone says the word "hypergear"
hypergear hypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergear
you there stao?
Stock BOV not blocked off.... currently "ssshhhhhh" or "peeewwwwwwwwwww" depending on the boost/gear
How much is one of these Great Scott intakes for a valued and handsome SAU VIC Member such as myself?
The noise barely changes as the stock airbox is designed to dampen it. With a pod? Then it would be loud...
PM me for info, I don't want to upset the mods... :P
you there stao?
I heard
If you type his name three times
At midnight
He appears and strangles you with a braided oil line
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
