Yeah I'm already blacked out... Thinking of doing the shiny brassy coloured wastegate actuator as well... Its the only thing that looks out of place atm. Exhaust Mani heat sheild in a matt black heat proof looks baws compared to the rusted old look :D
haha! yea do it.......... almost contemplated doing the inside of the engine bay black too... but that would have been to much. would look good with a white car tho...
Why do you need to carry jerry cans? Unless going long distance there are plenty of United servos around Melbourne.
I'm thinking more for track days/DECA. there's a station walking distance from my place.
Not sure how fuel efficient this pulsar is, battery always gets isolated so never recorded. isn't too bad when off boost.
will get 98 tune, see how turbo handles the motor and if I want more power/boost will go E85 and GTX2871
I also have a scotty intake with a factory AFM and Airbox on the other end of it. cost was about ~250 (for me). Good idea about sticking the rubber to the outside of it for the super paranoid though..
Scotty actually painted mine black, so he's well aware of Vic paranoia
That's because when Scott has nothing better to do, he opens up every single page of SAu and goes through them. It his way of being completely informed
hahahah!
so he desnt have some sort of webcatcher like stao, who knows when ever someone says the word "hypergear"
hypergear hypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergear
you there stao?
Stock BOV not blocked off.... currently "ssshhhhhh" or "peeewwwwwwwwwww" depending on the boost/gear
How much is one of these Great Scott intakes for a valued and handsome SAU VIC Member such as myself?
The noise barely changes as the stock airbox is designed to dampen it. With a pod? Then it would be loud...
PM me for info, I don't want to upset the mods... :P
you there stao?
I heard
If you type his name three times
At midnight
He appears and strangles you with a braided oil line
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
