Having 5 days off in a row every 2 weeks is too much. It gets to the point where you start buying shit not to be bored...
In other news, turned down my micolour respray window :( would have had it ready by December.
Anyone know any cheaper painter? (Other than DT?)
Mmm, not good Greg. Did trent offer any ideas on the cause?
What plugs are you running? Were they fresh ones?
They weren't, but it was no misses, no hiccups, pull after pull after pull, hours of it... IC was cold, AT Cooler was...room temp.
240kw @ 4000... and 310 at 4800...and 5k,6k,7k, 298 at 7500 etc. Did lose some boost, 26psi in middle, tapered to 21-20... prev run was 24? at redline.
Did a 98 run, 26psi (down to 21-22) and made 250kw lol. Same graph shape, though. 16+ deg of timing and no pinging.. 22 or so on E85.
Nothing of note changed (well transmission build occurred/new trans but went from a built NA to built turbo one).
Fingers pointed at IWG blowing open or manifold, or turbo being choked, though no reason as to why it should be any different than before as nothing changed...
Should prob clarify
First trip time, 20psi, E85, made 310
2nd trip/retune, 24 psi, E60, made 340, ran out of duty.
3rd trip/retune, "26"psi (down to 21?, E85, made 310.
Prob seems due to boost, but nothing changed :P
in other news, went to work on Monday and they want a letter from my neurologist stating that I am fit to work and to have her devise a return to work schedule
so i'm now starting on monday doing 4 hours a day for a week, then 6 hours a day for a week then full time :)
awesome employer is awesome
good guy NAB
Should prob clarify
Dat mod lyfe...
How does it drive though?
1010159_589155074484737_1421350236_n_zps By @gurber78, Justice for Jeremiah Meises (Jay Meezee!) The news tries to paint the motorist of the Range Rover Alexian Lien as the victim while Jeremiah Meises is the real victim who was run over by Alexian Lien whom left the scene of the accident. The video speaks for it's self. In the video Jeremiah Meises is wearing a purple tee-shirt he gets off his green motorcycle to help the guy that was first hit by the Range Rover and then he was run over by Alexian Lien who left the scene of the Intended Accident. Due to the severity of Jeremiah Meises injuries he was put in a Medically Induced Coma, he will never walk again. He is Paralyzed from the waist down with a list of severe injuries. Alexian Liem committed a Hit And Run. He did not stay at the scene and called New York City Police for help, INSTEAD HE TRIED TO GET AWAY, SO HE NEEDED TO BE STOPPED! Every single media group is running the misleading story that this was a justified act, that the biker only suffered a broken leg and that it was just a fender bender that cause all the bikers to chase down Alexian Lien. They are trying to make it seem as if Jeremiah Meises, whom will never get to walk his daughter down the isle doesn't even exist. Lets not get the story confused. First Alexian Lien hit one biker with his Range Rover. Secondly he ran over the others and then he drove away. THERE WAS A SERIOUS CRIME COMMITTED BY ALEXIAN LIEN
Poor Range Rover driver..
  • Like 1
Feel for that guy and I do believe the Range Rover driver was in the wrong when he ran over all the bikes.
Bit silly of them to say "let's not get the story confused", though, when they are guilty of doing that too...the first biker brake checked the Range Rover which was a dumb thing to do. I've had a bike do that to me before; slammed his brakes on in front of me and looked pissed off when my car hit his rear wheel...what the fk did he expect to happen!
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
