Having 5 days off in a row every 2 weeks is too much. It gets to the point where you start buying shit not to be bored...
In other news, turned down my micolour respray window :( would have had it ready by December.
Anyone know any cheaper painter? (Other than DT?)
Mmm, not good Greg. Did trent offer any ideas on the cause?
What plugs are you running? Were they fresh ones?
They weren't, but it was no misses, no hiccups, pull after pull after pull, hours of it... IC was cold, AT Cooler was...room temp.
240kw @ 4000... and 310 at 4800...and 5k,6k,7k, 298 at 7500 etc. Did lose some boost, 26psi in middle, tapered to 21-20... prev run was 24? at redline.
Did a 98 run, 26psi (down to 21-22) and made 250kw lol. Same graph shape, though. 16+ deg of timing and no pinging.. 22 or so on E85.
Nothing of note changed (well transmission build occurred/new trans but went from a built NA to built turbo one).
Fingers pointed at IWG blowing open or manifold, or turbo being choked, though no reason as to why it should be any different than before as nothing changed...
Should prob clarify
First trip time, 20psi, E85, made 310
2nd trip/retune, 24 psi, E60, made 340, ran out of duty.
3rd trip/retune, "26"psi (down to 21?, E85, made 310.
Prob seems due to boost, but nothing changed :P
in other news, went to work on Monday and they want a letter from my neurologist stating that I am fit to work and to have her devise a return to work schedule
so i'm now starting on monday doing 4 hours a day for a week, then 6 hours a day for a week then full time :)
awesome employer is awesome
good guy NAB
Should prob clarify
Dat mod lyfe...
How does it drive though?
1010159_589155074484737_1421350236_n_zps By @gurber78, Justice for Jeremiah Meises (Jay Meezee!) The news tries to paint the motorist of the Range Rover Alexian Lien as the victim while Jeremiah Meises is the real victim who was run over by Alexian Lien whom left the scene of the accident. The video speaks for it's self. In the video Jeremiah Meises is wearing a purple tee-shirt he gets off his green motorcycle to help the guy that was first hit by the Range Rover and then he was run over by Alexian Lien who left the scene of the Intended Accident. Due to the severity of Jeremiah Meises injuries he was put in a Medically Induced Coma, he will never walk again. He is Paralyzed from the waist down with a list of severe injuries. Alexian Liem committed a Hit And Run. He did not stay at the scene and called New York City Police for help, INSTEAD HE TRIED TO GET AWAY, SO HE NEEDED TO BE STOPPED! Every single media group is running the misleading story that this was a justified act, that the biker only suffered a broken leg and that it was just a fender bender that cause all the bikers to chase down Alexian Lien. They are trying to make it seem as if Jeremiah Meises, whom will never get to walk his daughter down the isle doesn't even exist. Lets not get the story confused. First Alexian Lien hit one biker with his Range Rover. Secondly he ran over the others and then he drove away. THERE WAS A SERIOUS CRIME COMMITTED BY ALEXIAN LIEN
Poor Range Rover driver..
  • Like 1
Feel for that guy and I do believe the Range Rover driver was in the wrong when he ran over all the bikes.
Bit silly of them to say "let's not get the story confused", though, when they are guilty of doing that too...the first biker brake checked the Range Rover which was a dumb thing to do. I've had a bike do that to me before; slammed his brakes on in front of me and looked pissed off when my car hit his rear wheel...what the fk did he expect to happen!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
