in a 33? not if they are 18x10
4x 8" will fit across the back seat but make driving uncomfortable if they have tyres fitted.
rear seat out = 4 18x10 in the back. two min jerb if you dont bother screwing down the seats every time. mig has a sedan. don't listen to him
Taxis and coupes have the same rear seat room. even without the doors it's easy, stand them upright on the back seat, you can fit 2 either side then push the front seats into them to hold them in place.
If you convert this wheel size speak into age and dick length with rubber meaning condoms, this conversation gets pretty nasty and car orgy sounding / lined with in ur endo.
Managed to fit 3 panas and 4 ad08's in the gtr once, another panas went in the boot.
Can easily put a set of 18x10 with 285's in rear seats attached.
I have always run 18x9.5 or 17x9.5 and have had 4 rims with tyres in the 33 more times than I care to remember...
have also had a 17x9 with 235/45/17 in the boot where the spare tyre goes
lithium is just a shitflamin mongrel
also I dont care if you get 18x10+38, they will look fine, but you still should be rolling your guards.
also, unless the motherfuckers are free I cant see how spending 11ty billion dollars on pertrol is gonna save you a dime.
best to get XD9's brand new from jesse streeter.
car looks good hamish
looked at another evo 8 today
asked him on the phone, whats wrong with it, smokers car etc? nah all good , no issues, non smoker
rock up
smelt of smoke, cigarette in the ash tray
wouldnt go into reverse properly
bonnett doesnt line up
rear bar different colour
both diffs clunk going at low speed around a round-a-bout
at least it had no rust
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
