this happened....
was during the cannonball run... driver and co-driver died as did the 2 officials they ploughed through
if you are too young to know what the cannonball run is i will just kill myself now.
this happened....
back when the cannonball runs were done at speed.
well the full story.
there was a cannonball run in AU between Darwina nd perth.
there were a number of check points along the way.
SO rules were you had to slow down to around 100 for the check points and towns and full throttle in between, this guy came into the checkpoint at about 250ish..and lost it,
race cancelled, ppl died..
Ham what a cheap paint job did not even do the door jams ;)
this happened....
I know what the cannonball run is just didn't know of this accident :) waste of lives and ferarri :(
Apparently the 285 18 Achilles 123s are better bang for buck and cheaper than 265/35/18 Federal RSR.... AND they're about the same width because RSR's are wider than 265's should be so will fit under by rear end without needing to roll any guards?
Thoughts? Comments? Which tyre should I go for now that I've decided to do Winton on the Friday before DECA in Nov?
Edit: Just need the 2 rears, 18x9.5 (can't remember the offset...) since I've still got enough RS-R on the front to last a few days.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
