Restriction is the turbo exhaust housing I believe...
3" JJR Stainless Bellmouth Dump/Front pipe
3" Highflow cat, which isn't even a 100 cell, I think its 200 or 300?
and it was pretty much a straight though system with the Kaki R (2 mufflers)
You gonna come to the ethanol side anytime soon? Keeps the backside nice and clean :)
Nein... I do too many km's to be even more inconvenienced by needing to be picky about which servo I can go to... Would need to swap turbo to get the most out of the extra power as well...
if i ever plan on going to Vietnam i would do something similar.
Was actually planning on going to Panama last year to do a 9 day kayaking trip through the carribean. i pussied out though.
Got some pics
Accommodation at this beach was $10 a night for a cabin and $25 for a pimped out room
  • Like 1
I only gained 20rwkw up top because of my small turbo, but in some parts of the midrange I gained 40rwkw. Plenty of Uniteds around; there's one 5 mins from where we live (near Alvin) and a 24 hour one off Eastlink in Scoresby. So worth it!
Come on Scotty gimme backup...
2835 KGO!
hmmm vietnam...been there 7 times now...hated it more and more everytime
that said I'm a special case for my trips as there for work.
So booking flights for my next holiday in next few days.
Thailand - krai
Philippines - boracay
Fiji - denaru isalnd.
hard to decide
You just can't tell some people.
If Simon wants to be different and run Dinofuel who are we to single him out? He will come around one day, probably just after his ring lands go. :P
just too mut f**king around to go etOH,
so i'll stick with dino fuel.
most importantly without a proper jerb, no budget here.
If you've already got a tuned 98 with safe supporting mods, it's as simple as a tune. I don't even have a wideband. For the extra $500 or whatever your tuner charges, worth it to have an ethanol tune stored on a laptop should you want extra power for a given time period. I keep laptop in my car...if I don't have an ethanol station in sight, just go to a place with 98 and switch to 98 tune. Simples.
Thailand - krai
hard to decide
What do you hate about it? I think it's amazing someone could live like an absolute king in Hanoi. $450/week apartment in Melbourne is about $300 a month there. Get a small passive income and you're set for life. My only complaint was no chocolate milk, and no milk in general. Damn lactose intolerant Asians.
no tune yet. but nistune is on the cards.
can i swap tunes with nistune?
the general attitute of the locals.
DUe to working there for significant periods of time I got to know some.
they sit around with beers on a Friday discussing who F%$ded over the tourist the most as a joke.
only place I have been robbed
and then the hygiene, middle of town, watched lady carry baby into the street, hold it above the gutter so it could "go potty" then bring it back inside.
and the gourmet cooking:
So yes can live cheap, but a life I don;t want, where for less money I could be in Laos that was much better, or a little more gets you thailand.
my objective is to never go back.
Laos
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
