VF GTS is about 100k on road as far as I remember, pretty sure they come with AP racing brakes too?? (even though they probably say HSV on them)
My mates boss has one reckons its decent for a new stock car
Even still brah I don't think you'll get one for that they command a premium
especially 1 week before race wars
I'd hate to have 100k to spend on a car
Suck it up princess
f**king lol
  • Like 2
So those playing at home, got the iPhone 5s.
Ported over my iphone 4 apps, photos and all in a couple of minutes.
No messing around, simple is best.
Bought a Nexus 5... Booted it up for the first time, "Would you like to install the apps which are currently installed on your Galaxy Nexus?" Yes plz. 5 minutes later everything is perfect.
Agreed, Simple is best.
  • Like 1
N5 > IP5
That will be all. How are you liking it so far, Simon? I played with my mates the other day, quite smooth. I appreciate the slightly extra screen real estate over my N4 as well.
N5 > IP5
Tbqh it doesn't feel like I have a new phone. It's all the same as my 4s.
Barely notice the larger screen. Finger print unlock is fancy though.
I'm loving the nexus 5, it's not too big like lots of people have been saying... Considering I've come from a 4.65" Galaxy Nexus to the 5" Nexus 5 its not a huge jump in size...
Battery life is awesome, Push Email + Facebook notification + a few 10-15min phone calls + Whatsapp and SMS all day long, and I was coming home from an 8 hour day (plus an hour of driving each way) with 75%+ battery life
It's light, but still feels really solid and well made. If you're going to get one, I'd recommend the black. I got the white and now I can't use it in the garage like I'm used to :P My GNex I'd pick up with grease COVERED hands and zero fks given, just give it a wipe on my shirt when I was done... It's a bit trickier to clean black off the white back cover.
I'm honestly not sure how Apple manage to make so many people splooge over the most minor incremental upgrades... People rushing out to buy a $1000+ outright phone, sure its got a slightly faster processor... but all the apps are designed to function on the lowest common denominator (which is the lowest phone running the current OS, iP4S) so you don't really feel the power boost anyway... I'd love to buy a beer for the guys in their marketing department, they sure as hell know what they're doing :)
Edit: Speaking of keyboards... I've just installed a new one called Fleksy, really intuitive and easy to use (after the day or so of un/learning curve). Just wish it had some swype like functions as well. but other than that, its really accurate and smooth as butter.
C63 must be due for new model starting to look dated IMO
Aaron could confirm?
need aaron's insider information! :P
that's true. they black edition coupes are still hawt, though!
sounds good :)
my n4 isn't even a year old tbh, although given the price point i could upgrade to n5 for not much, i'll probably wait it out until the next gen of phones/nexus.
i use swype these days, good stuff. only thing i hate is the stupid lack of return key in the messaging app... but that is google's fault :P (i wonder if it's any different in hangouts... not sure i want to use hangouts)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
