On the topic of who's buying what, GF just bought a lancer ralliart - will be fun to try out the DCT
brand new or a couple years old?
if not brand new/warranty isnt an issue, with a simple retune they will make more power than a stock standard evo 10, you can also flash the gearbox to make it shift better. beeble is the man to talk to http://beebletune.com/
Welcome to the gud lyf
Chuck up a dyno graph Easy E-85
Got no graph at the moment
Got an issue with the car. Its pointing to faulty injectors
So on a trial run with 8 degrees less timing it made 315rwkw @ 4,500rpm before Trent had to back it off
The hooters sauce is actually pretty good, I like to think I make pretty good buffalo wings, a lot of people have had mine and they reckon they havnt had better. So I'm pretty proud, although it's not that hard to make lol
What is it with Lankan's with wings.
Best I've ever had were some my mate who from Sri Lanka did for us
maybe you have same recipe!
Shieeeet still got 3000rpm to go. Massive figures.
Toby pls
Huuuuge numbers brah
Yeah I was only hoping for 320rwkw+
Rev limiter will be set to ~7,800 to 8,000rpm pending so will sure be interesting.
Trent thinks ~400rwkw
Might have to ask for a detune otherwise be too scared to boot it :mellow:
Huge power for RWD Skyline, almost too much lol. But yeah, might as well take advantage of the huge power and get Trent to make it a conservative tune for longevity! Just be careful with third gear...albeit the most fun, they are also the most susceptible to instant gearbox destruction in GTS-T and GTR boxes (especially). What rubber are you running?
Also, I believe you owe me a post-tune ride in your vehicle, Tony.
09
What's better? Faster? Crisper? Gentler?
Picking up this weekend, will be pinching keys quite quickly
Be me
Drop r34 off for transmission work, before 6 week holiday rattle abounds (auto)
Told 1 week
Told no problem
Go on trip, life is awesome for weeks
Return
Car not ready, can't find part over christmas
Ok
Still have daily, eta 1 week
Daily dies 1 day later
Shit. Obtain many lifts
Pick up car on birthday
Pay 2000
Car dies 20 minutes later on highway due to dead fuel pump 5km from barwon prison when you live in eastern suburbs
Hope your day was better!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
