lol
tbf tho, cant see me having another holden anytime soon. clubby hasnt given me any issues, considering its a 12 year old car im very happy, but ive had my big engine phase for a while now.
how do you design a car that goes through wheel bearings every 20-40K
And you need to angle grind the bearings off the hub.
Bring back tapered roller bearings, pack em with your palm full of grease and they go for years.
I'm with you after this one never again.
that bad really?! wow.
my sister focus had a clutch that used to slip real bad... ford wouldnt replace it even tho it was 12000km old, they took it out said there was no signs of wear or anything and put it back in.
guess what.
never slipped again until she sold it 10000km later.
shame about the rest of the car tho, indicator stalks failing, stereo dying, air con f**king up etc etc.
It seems that 3/4 of cars that I see on the road with tail lights out are VE's...
Every single day I go... "ANOTHER ONE!"
It's as bad as seeing a car blow smoke when moving away from the lights, and then going... Yep, it's a Magna...
  • Like 1
same with my kia. 2 years old. blows a headlight ever 3-6 months. kia have no idea why.
picked my A5 up yesterday, over the moon with it!
had ceramic pro put on it today, lets hope i never have to use that lifetime warranty!
Shoulda bought a ford brah
jokes
Did you apply the ceramic pro yourself?
Is that some sort of good paint protectant?
Pics brah
ill grab some later :P
jokes
its a paint protection which is almost like another clear coat, it dries hard, can only be removed by cut and polish pretty much and comes with a lifetime warranty unlike most other paint protections which are 1 - 3 years.
shows how it works pretty much.
I had Levent from prestige specialist detailing do it.
leroy that sss for 1500...... manual yes? are they all manual?
Ive just asked. will PM you details when I get info, its a bit rough round the edges, but will need half the work the mirca needed (lol)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
