The GTR badge has legendary status and personifies the pinnacle of Japanese performance motoring. It is probably the most renowned car to come out of Japan. To stick it on a $4000, P-Plate Skyline bucket with stickers all over it and drift toys hanging off the tow hook is a sin. The misfit deluded owners who do this should be shot or put through counselling and/or psychotherapy.
Lol the way i see it, for an R34 for example
R34 GTT is like a base model Comodore
R34 GTR is like a Comodore SS
Nismo R34 Z-tune is like a HSV GTS
Double standards of R34 GTR butthurt that cars look like GTR's but they make there own cars look like Z-Tunes
  • Like 1
Birds have you tried (that which I assume to be relatively new) Kebab place near DM?
Not yet. Will give it a go. They all taste the same to me to be honest, bar slight variation in meat quality, cause my kebabs have simple ingredients. Lamb and chicken with cheese, bbq sauce and chilli flakes.
hey Martin
..my mates in Germany and he got that insurance you suggested...now they are having issues because policy isn't in German something or something and they aren't sure what he is covered for...So he had to send a request to insurance company bit because it was in English not German they didn't accept it...
You ever have this problem?
Pretty sure I've eaten there before. That's what I'm looking for just slighyly less dingy.
hey Martin
problem with paper work in germany. lol
you make one mistake, just start again.
i love that place.
hey Martin
never had the problem, who is asking for info on insurance?
unless your making a claim I've never ahd some-one ask to see my policy?
so do i cancel the GTR badges we ordered or what?
  • Like 1
yeah not sure how it came about...they just said this policy makes no sense and asked for further verification...
sure he will figure it out just having a moan about it no doubt
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
