they're as bad as the french whores...speaking of which you are catching up to me too
if you're talkin about post count I can't see anything cuz I use the phone app dude.
Really don't care bout post count anyways - it means nothing except demonstrate you can post a lot on a public forum ........whoopty f*ken do
It's about that time of the semester; at which I think to myself as I sit here staring blankly at a 1500 word report due tomorrow - "is this all really worth it". #unilyf
1500 words can be done in under 3 hours, so i guess, its not too bad?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
