Friday 4:15pm... For lunch I had Sangria Duck Ragu pizza and 3 glasses of champagne
Zero work shall be done this afternoon... Can't wait for Winton tomorrow... though just looked at Google Maps, gotta swing past Heathcote first, bloody nearly 4 hours one way. Blergh.
How much for a detail?
How far do you live from Frankston Hospital?
How many hours to do a black ute roughly?
just around the corner from hospital mate.....if its not too bad i should be able to knock it over in a day...but yeah depends how good you want it and how bad it is to start with...
im busy next week now it seems, but drop around one afternoon I'll have a look at it and we discuss...I'll pm you my address and stuffs :thumbsup:
pickup car monday afternoon woohooo
and my dell desktop had a wierd memory issue
random reboots, bluescreens and wierd random windows errors
reinstalled windows the same, spoke to dell, ran bios diags and it found "memory errors" and somehow marked a few memory addresses as "bad"
now its working sweet and it passes all the memory tests
i didnt know you could do that with normal DRAM
with ECC of course but didnt know the BIOS was able to mark certain blocks in memory as bad and skip them
Thanks for putting my phone number on the internet f**k face
You want some personal training, go do pullups with a length of rope, using your neck
jsut post his on an alternative dating site
or use it to book in some visits from mormons/scientologists
30% off Repco this weekend guys.
You'll need to be a VIP member though. It's free to sign up from here:
http://vip.repco.com.au/registration/register/1141
Once you sign up you'll be sent a temporary card in your e-mail. Just print it out and take it to the store.
very nice, might get myself a new jack this weekend then.
damn. pizza sounds good?
you coming tomorrow? hope Miguel is gonna make it worth your while :P
made it to be malls in one piece. got 10m through Clayton back streets before I had to break up a domestic dispute involving police to ask whoever the owner was to move their torago at least 1m closer to the curb as trailer wasn't going to fit #easternburbs
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
