Do the new changes apply to people that already have club reg too? My mate mentioned it tonight and seemed to think it will, which is what the mazda/rotary clubs said in their posts about it...
My mate just bought a VL calais, been in storage for 12 years, has 180,000kms, log books, in 100% original condition... Something Mohomo would appreciate....not me however.
Well because they were generally show cars or historic cars...they traditionally didn't use the road very often so why should they pay the same rego as you...
Unfortunately people abused the system and took advantage of its loopholes...So those holes have been filled
what does yours have in terms of mods etc
and how often you driving it? is it daily?
also dont think ive seen pics ?
Mods = f**kall as I lost interest after having a baby
Hamish
new rules coming into place for the club rego
you need full RWC and no mods outside VSI-8, ie exact same as having normal rego now.
so if you doing it, get in quick b4 rules change.
http://www.fordforums.com.au/showthread.php?t=11419038
it's retrospective :/
Haha I reckon it's because of the mass flood of all imports becoming eligible for it.
pretty much
For an engine worth $200, and it comes with a free Micra, you seem overly worried to blow it up...
Don't listen to your pommy Micra poof mates, they don't know squat about ethanol/e85. Send me the link to your thread so I can teach them a thing or two.
  • Like 2
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
