hey if i plod around in 2nd gear and low speed the car is quiet jerky
not beef jerky, but kinda engine revving jerky, almost makes me look like i cant drive
is that the mega cams doing that?? is it something i can tune out with more or less ign timing?
only happens on light cruise in 2nd gear at low speed, if i open the throttle it goes away
Big cams on a little motor can do that yes.
lol evo life
mate's 8mr which was pushing a bit of power did that too. first time it happened i thought i had forgotten how to drive, lol.
mine's still pretty good atm tho at current power levels. we'll see how it is after next round of mods... (no cams tho, so here's hoping... ain't nobody got time for dat jerk)
lol evo life
Usually happens due to running lean at idle as I found out last night, then again today with Greg's car. ;)Cams would make it much more pronounced.
You got widebands fitted guys? Why the hell not?
I copped that coming back from Singapore... Was golden
Can be better than business class stuck in their individual seats :)
Though you would have needed some leg fold surely
Captain just said 40 on this A330 including business class bahahah
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
