Not that that isn't a lot of dollar, but thought you'd be running into people worth more than 100mil. Where's Gina?
Gina flies in her private helicopter so I doubt I will cross paths with her.
She starting up her own iron ore company so would be rare to see her.
KFC double is back this weekend.
Boo yeah
Will try
She should start weight watchers.
  • Like 1
Old school track Celica's aye
Should be seeing this one at the tracks soon
Stripped, built motor with a big external high mount Garrett 3582 and lots of other funky stuff
Celicasupra is what that is, got a mate with one. He's taking his to DriftX in November, a pretty luxury car for the mid 80's imo.
nah this one a celica, the supra had some body changes like flared arches over this one.
''Tragically, each year about 40 trespassers are fatally struck on our network and there are a further 20 who sustain serious injuries,'' Metro spokeswoman Leah Waymark said. ''This impacts many people, including our drivers and staff and their families.''
would NOT want to be in that 20 :no:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
