That's what's doing my head in. Suppose I'll have to take a passenger ride in someone's gtr to see if they're all they are cracked up to be
In this day and age it seems a well sorted gtt/gtst and a well sorted gtr are much of a muchness as far as actual speed is concerned, unless I'm wildly incorrect
  • Like 1
went to a steak house and ordered their top steak to be cooked as per chefs recommendation, just like wasteland said.... "I'm sorry but you'll have to pick something because I have to write down the order for the kitchen"
Speed perhaps, how they are to be driven is very much not the same though.
Ask to speak to the chef, and then tell the chef to hit the waiter over the head with a spatula...
Chef's recommendation coincidentally blue everytime for less cooking effort
inb4 Hamish hates me
  • Like 1
I'd assume the difference may be traction
shitcunt waiter :/
Actually...
Contrary to popular belief, bleu (it's French fgt) is annoying as hell for a chef and takes longer to cook than a med rare etc.
You have to get the steak out of the fridge and leave it somewhere that will warm it through all the way to room temp without cooking it at all... Which takes ages... THEN you have to cook it... THEN you still need to rest it.
Bleu takes as long to cook (properly) as a well done and ends up with complaints more often than a well done
Actually...
lol i can imagine.
It's just nice to be able to drive on the street with 330rwkw and not have any fear of a full EPA or Defect. GTR engine bays can remain completely stock looking and still make that power which is great. The others are correct though, depends what you like driving more, I've owned 2 33 GTS-Ts, a 32R and now a 33R and the 33R is just miles ahead of all of them.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
