So at court - observing not guilty of anything! I truly don't think I've seen so many polished turds in one place.
Baggy jeans with dress shoes white billabong belt tucked in Hawaiin shirt with a man to man suit jacket with popped collar
Classssyyyy
  • Like 1
is my membership still current? it says that i am but i dont think so
Mohsen Younes
Standard
Started: 19/09/2011
Expires: 21/09/2014
You just squeezed in with a week to spare ;) Renew for another year at the cruise or we'll throw eggs at your car and chip off all the bog from the rear guards.
so suit cases:
I really like Samsonite.
Strong good warranty and light, but yeah $$$
my suitcase, suit bag and carry on all Samsonite and moving up to this one next week:
Katie uses antler nearly as light and very happy with that.
But alot comes down to how often you use it.
If it's once a year do you want to spend 5-600 on a suitcase, probably not.
if looking at something a little cheaper I strongly recommend American Tourister:
http://www.strandbags.com.au/luggage?filterset=filters&filter=BRAND&filtervalue=American+Tourister
it's Samsonite "cheaper" brand. so they slowly get the older Samsonite tech and good build quality.
Also never buy black unless you want to be one of those folks that has to check every bag on the carousel
.and customize it a bit.
All those free stickers you get with car parts i've been putting on each side of my old one so I can spot it a mile away.
Even some ribbon or a strap, just something to help spot it from a distance when some-one has grabbed the wrong bag is is heading off with yours.(yes this happened to me)
so suit cases:
Ha that's happened to me also, mine was leopard print though.
I have stickers all over my suitcases too :)
Classssyyyy
Dress rehearsal for the upcoming spring racing carnival
mate bought an R33 GTR, that had been in a small accident, got it home, thing wont spark or start, fuel pump wont engage.
proper dead.
then we found out the previous owner had ripped half the fuses out and drained the tank before insurance looked at it to ensure he gets paid out lol.
all good besides a cooked ecu.
feels good helping dream boats after being through hell and back with the same shit.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
