8mr for 20 is good value
check j-spec auction results, you can have a 8MR landed and complied grade 4 for sub 19
so yeah should be around same for one here..no matter how much a few ppl in denial.
2004 LANCER GSR EVO 8 MR 2,000cc 97,000km Grey MT 4 1,130,000 yen $18,800
2004 LANCER GSR EVOLUTION 8 MR 2,000cc 105,000km White MT 4 1,138,000 yen $18,900
example.
Low KM
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-2743357&Cr=0
but bet you could do a deal for 20.
Yeah well I'm going to start calling some different Sheriff's Offices to see if one of them goes "Oh yeah theres actually a form you have to fill out and it'll be cleared" or some shit like that and maybe the woman I spoke too today just had no idea about it, who knows. I'll definitely be following this up relentlessly though as I'm not gonna be happy with the harassment.
Easier to replace whole diff
There are many R200s
Interchangeable to a degree, both in diff centres and diff housings
Depends on pinion length; ABS vs non ABS. Think the splines are much the same, so in a lot of cases you can swap half shafts over, e.g. putting 6 bolt GTR flanges in a 5 bolt GTS-T diff.
I have an S14 ABS diff in my R33, that got rebuilt with my R33 KAAZ 1.5 way while my car stayed on the road. Then just swapped the diff and half shafts for quick installation. Ratio is a tiny bit shorter.
Before i start googling, R200 diffs... Easier cheaper to install diff inside existing, or just replace the whole diff? Are they generally interchangeable?
Mike and I (ok, mostly Mike) rebuilt the centre of my R230 with new nismo discs and swapped it over to replace my old A-LSD R230. Was a pretty simple process, but there's a lot of things that you need to know before you start... marking certain threads for the pinion etc so your backlash isn't stupidly lashy when you're done.
mk thanks for the info. gonna have to drop the rear subframe to some degree to put springs/coilovers in, thought might be worth having a look at the diff. got told its an R200 series, but only way to know is pull it off and open her up i guess...
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
