hmmm I guess there's no Eco buyers regret when you have a faster track car...
this means you can get cams for the skyline when you get E85 tune, yes? and dot4-5 brake fluid, and more aggressive pads. and remove aircon! :O
Yep, but with car or construction based DIY I still find it worthwhile for the satisfaction of doing it yourself.
I don't get that with making lemonjuice in a spray bottle to spritz on my shower tiles...
I just piss on my shower tiles on daily basis, much more economical.
  • Like 1
Immobiliser. Alarm stolen in previous break-in and was about to be replaced
Car was in underground garage behind locked gate, but visible from the street
This is why my last one was stolen! Dat feel...
What area was it stolen from to narrow it down a little Ric?
Ironic criminal stole an alarm?
And motherf**kers act like they forgot about drez
It's really concerning these days that you aren't even be safe in a locked garage. Used to be they would pinch from the street only. Then they started getting tow trucks for those with immobilisers. Now they going behind secure premises with immobilisers.
I thought Vermont was safe too
Realistically though, no alarm but had an immoboliser, pretty much means they can keep on rewiring it until it starts, or until they get spooked one or the other. Sucks but I guess thats why Ash always says, spend little on the alarm gear, lots on the installer.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
