you're right. the one i have is 12v rechargable battery. comes with powerpoint and car charger, cost me $48 or something.
You can buy them for $15 at Kmart, will prob buy one tomorrow.
Why does no-one want my R33 GTST Fuel Tank? Its free for rajabs sake!?
Dude...R33s have depreciated that much in value
That their spares have to be paid to be taken away
I just gave away heaps of stock 33 bits, had heaps of people wanna grab em within minutes, stuff people actually want that don't require half the car to be pulled apart to install though :P
So last chance before I go ahead and take the plunge on a new front bumper. What do you guys think?
I can't actually find anything better for the price. Eastbear requires a new bonnet and bumper, not to mention the real copy is incredibly expensive.
Will also be buying these: http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-front-indicator-set-clear-genuine-nissan-nissan-skyline-r34-gtr-20gt-25gt-25gt4-25gtt-gtv-p-759.html
Any suggestions for something else?
haha, to be perfectly honest I'm not a huge fan of R33's. They are nice, but I just see them everywhere. The R34 has much more iconic styling.
You see them everywhere for a good reason.
They look better than 34.
*i secretly like 34 only cos these cup holders.
  • Like 2
Oh Cup Holders, how I miss thee...
33 Series 1 look like arse, Series 2 looks a lot more modern and aggressive and clean.
My order is 33 > 32 > 34 > 35 > 31 > 30
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
