I wouldn't put it past autobarn audio installers to accidentally snip an airbag wire while putting in a fully sick sony xplode headunit ;)
All about the peak watts brah
Dat clipping
because chickens are very absent-minded creatures. the chances are the chicken saw some form of bug or other edible life form from across the road and decided to venture over in that direction. if the road was not there, the chicken would most likely have still crossed that same expanse of ground, regardless of potential consequences.
in all seriousness holocaust stuff isn't funny, its only funny because of how absurd and so on it is, and its that absurdity that is the funny part
anyhow,
Airbag wasn't triggering on car prior to it receiving my original engine and transmission and ECU's.
It is now. However, the SRS system is supposedly a self-contained system/unit with its own sensors, wires, and so on. Changing an engine shouldn't trigger it from what I can see going by the workshop manual.
Everything is that distinctive yellow, and there's a plug where the stock audio is, except this one is bright yellow. However it terminates short and there's nothing obvious to plug it into. Unsure if unfortunately coloured or god knows what.
Dunno if its even for the airbag, but its suspicious because nothing else was altered and the system won't even enter diagnostic mode to give me flashing lights to find out whats wrong with it all. Given this mystery plug is behind the head unit figured someone may have seen it before when they do something like... change a head unit which is pretty much done in every single skyline in australia
Srs plugs are yellow, I'm betting you're missing an srs module or something
not heard that, every-one I know that went there drank. hell my old man would not have survived if it was dry!
Was informed that Ankara is dry zone, but I shall find out if it's the case.
I know most aren't dry zone.
fark that's bad
whats considerably worse than the holocaust is a flashing airbag light
autoelecs attempt and fail, recommend replace items that aren't broken (replaced anyway)
Nissan workshop manual is inconclusive and provides not-possible diagnostic results
google fails
sau fails
genocide is preferable
You still have the stock ecu so can't my consult 3 plug into it to read stuff Greg?
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
