Hay steak guys.
Ishiya (jap stone grill)
Or
Rock pool
Which to go to. And what do u recommend at these places/tips
Take that bitch to Maccas, bitches love Maccas.
30 pack of nugs and you'll get more than hugs.
  • Like 1
lol fresh fruit/veg/meat from market for average 2 person household = $100 per week
average fast food combo meal for 2 people, twice a day = $9 x 2 x 7 = $126 per week
add breakfast as well at say $6 per meal and we are looking at $210 per week
  • Like 1
Alternatively go to The Fat Duck and spend $725 for a Tasting menu and matching wines. Don't have to get up early to go do the markets that way...
but you have to enter some phaggot lottery to get a seat...
LOL had to go home and take a shit.
seriously, the cops in the area dont give a f**k.
the last time we stumbeled on someone dumping a stolen car we called the cops, who rocked up 2 hours later.
we literally kicked it for 2 hours and waited for these dream boats.
that said we lost the dude and ran into some coppers, one of which seemed to know exactly what an evo 6.5 looked like.
hope they worked a little harder this time.
Hit up pccg, scorptec, umart, and msy too.
I don't care if it's from centercom, but I want to purchase it in person... All the online joints are cheaper than centercom so I'll call em tomorrow and see if they'll price match
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
