Also make sure the brakes and brake pads are perfect, bring a spare set of pads just in case they decide to run low... because Sandown chews brakes badly... Slow cooldown laps of the track (and the carpark) and necessary as there's two x 200km/h stops per lap.
yeh got heaps of alloy sheet and a bender so spending all week end making the ducts on the GTR bar useful.
kumho V700 Should do a good job keeping the back end tame.
Got an oil cooler Moh?
If not you might need to look into that
Otherwise your car will be 120c + after 2-3laps
planned list of shit to get done
oil cooler + filter relocation
brake ducts
cooler and radiator water spray
tyres
swag.
I'll come and drop some off to you tonight...
I'm bringing Dezz along
f**k yeah threesome.
The royal salute hundred cask selection bottle wasn't actually bad, also had a nice box/packaging as well
Bringing in your boyfriends coilovers from the front doorstep becoz he's FIFO. #justgirlythings
She doesnt lift, and the box probably weighs as much as she does. Didnt think to open the box...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
