Meh.
All i see is pricetags. Mustangs never really does anything for me.
Yeah expensive car for sure, at first I thought it only had the roush engine, then saw wheels etc etc
Tips for voting in elections: vote for the cocksuckers that will f**k you over the least. That's it
That's if you vote
Like the konis and h&r combo I've got in the wrx, fantastic thing to drive on street and out the track as I found out yesterday. Inspires confidence to the point you're not worried about giving the keys to mate to flog it around the track!
your mate was a shit hot driver tho.
he has alot more mechanical sympathy than you too hahahahahahah.
After riding passenger with Jason I must admit would be tempting to get the GS some brakes and an intercooler and get back out there.. but then I heard about Ash's stack.. nope.jpg
That VE GTS (not the new one) was hammering it around in our session
Maybe I'll get some leathers and take the bike out..
Edited by UNR33L
What happened with Ash's car?
Borci made the mistake of taking out his girlfriends father in his GTR and overtaking the Ferrari... Because nothing says "Your daughter is in good hands" like travelling 200kmh in the same car you come pick her up in
Putting aside my one eyed liberal voting our area really needs the east west link & labor scrapping it is going to set the state back decades
  • Like 2
Putting aside my one eyed labor voting... agreed.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
