Borci made the mistake of taking out his girlfriends father in his GTR and overtaking the Ferrari... Because nothing says "Your daughter is in good hands" like travelling 200kmh in the same car you come pick her up in
lmfao <3 borci
I should do that... My gfs dad thinks his 135i is faster than the pulsar. Convertible does not equal more killawasps
Lol if the gfs parents knew half the shit I've done with her in the car / on the bike.. pretty sure I wouldn't be allowed back in their house
Same as Leeroy, they have a maz 6 sp2.5 or what ever it is and think its fast - thats cute :P
Yeah I'm sure we're about to have some redundancies now that east-west link isnt going ahead, we'll (CAT) be missing a lot of work I know they have been hanging out for that a long time.
My pop thought his 6 cyl EF Falcon could do 0-100 in 5 seconds, so like everyone else on SAU I had to bring an older generation of wishful dreamers back down to earth
Achilles tyres, do rate for the price that's for sure. (at least in a straight line, yet to try and put any power down around corners)
Now I wonder what the wear will be like in the near future.
Birds any news on your bike? what you looking at getting next? 2015 r1 do ittttttt
Edited by UNR33L
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
