I've never had a steak go cold on me, apart from the 1kg challenge I did...
What if you're no good at cooking steak...?
And if you go to a good steak restaurant /good restaurant in general, your steak will be juicy
Well true it doesn't go cold, but a normal steak doesn't stay anywhere as hot as stone grill. It's like that first awesome bite of steak, but over and over again. Old man travels across town just for it haha
Ain't really cooking it yourself anyway, cause it cooks quick enough that you're pretty much just cutting pieces from the block as they cook; it's hard to screw up unless you're a real slow eater, but can always pull steak off the stone I guess.
Haven't even taken delivery.... just signed contract.. should have it in a week.
it's not exactly a 300rwkw R33... but it is far more convenient for driving kids around which now make up some 99.27% of my driving
lol @ single mum.
is $160 fair price for A/C re-gas? (from scratch, not top-up)
bit tasty, but its summer so 30% increase.
check out cranbourne auto elec. ihe was a top bloke, charged me 180 for a service, few orings, labour for repair and gas on wrx.
Tony have you got the dyno read out from your 380rwkw with a 3" exhaust? Boss has told me in the past that it's almost impossible to see over 330kw with a 3" exhaust.
Yeah it was on Trents dyno, did a drop of the exhaust and no restriction
Its a jjr 3 inch dump and cat, then get slightly bigger to the muffler
Refitting for that new style refrigerant as well?
Y34 should already be R134a, even 33's are already. 32 etc need to be converted from R12 doe.
AC in the new RS is f**king awesome. Have receipts for regass done in 97 and then again in 2011. On the way back home from shitney had to keep turning it off cus it was too cold.
  • Like 1
  • Like 1
aye is pvc pipe okay? Ill use the proper plumbers cement.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
