17s not good enough?
not with the brakes planning
i think aaron managed to fit those on a 14 martin.
with 295's?
it all good going to have some fun with the car this year.
start lining up some parts to fix the cosmetic issues and make go faster at same time.
good time to be alive.
Was thinking the same thing... going to be 2 streets away on Saturday, so was going to pick them up then... wait a second...
Subtle visit to RacePace
It's handy living two streets away from both of them
Couldn't have picked a better suburb for modifying cars
Really not that subtle...
Heaps of other stuff in the area as well, paint shops, bolt shops, total tools, bursons, etc
Things that I need to travel 20 minutes to get to, when I realise I need something at 4:30pm on a Sunday
  • Like 1
one ring to rule them all..
well all the money
i just dont get why you need to get an engagement ring AND a wedding ring...
sisters engagement party tonight. says on the invitation "No gifts please". go to my parentals... "you better get them a gift!" why? "cause your family"
weddings pls. farkin gives permission to be retarded and charge money for it. its like GTR tax cept that shit is fo'eva
  • Like 1
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
