we did that...
no need again unless there something no-one told us.
now it all in the motorsport area...
no.
has anyone ever been given a "its me or the car" ultamatum?
how did you react?
m's pods and elbows arrived today.
new garage door remote so i dont have to walk around to open it.
and some other goodies.
thats my reaction
no.
how did you react?
thats my reaction
I would marry my car if I could
That moment you realise the BBS LMs on your car are 17", not 18"
Oh well, shouldn't be too hard to offload the cheap AD08s. Can whack two on the GTS-T and sell other two, or could swap the LMs for a set of 18s in something else...just can't think of any particular wheels I really fancy...
i just dont get why you need to get an engagement ring AND a wedding ring...
sisters engagement party tonight. says on the invitation "No gifts please". go to my parentals... "you better get them a gift!" why? "cause your family"
weddings pls. farkin gives permission to be retarded and charge money for it. its like GTR tax cept that shit is fo'eva
I've a solution to this problem.
And best thing is, it won't end up in the cupboard under the sink.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
