I find it a little scary that your life can be messed with, for better or worse, simply because of what a computer screen displays...with very difficult or non-existent avenues for getting it changed. It's not corruption proof, but it's fairly repeal proof.
Reminds me of that movie The Net.
GTR registered
No RWC required
Guy did have a weird look on his face when he walked out to see it on Jack's tow truck. Also saw Russell there coincidentally.
Noice!
stick it to the man, man.
saw a strange car on the road today. an older man, driving a de-badge toyota or some sort... i suspect a AE95 JDM sedan. Stock everything except a towel across the back seats. It was beyond pristine. the rear mud guards were like brand new, the paint put most show'n'shiners to shame. the chrome on the (stock?) dual exhausts looked fresh.
Did someone really do a full restoration on what im pretty sure was a late-80's corolla?
Had classic (not historic) white text on black numberplates. the old skool ones before green.
haha did you pull up in the inspection bay with the car on the tow truck? Did they need to check VIN etc?
Yep
I said it has a bad engine knock and I'm taking it to my mechanic before driving it on the road, which is true. He just confirmed the chassis and engine numbers (spent ages trying to read the RB26 engine number, lulz were had), then we swapped the numberplates over and nek minut registered.
Yep
We have customers who get the works done on their cars, spend big money on it, THEN go to vicroads to get it registered... Very ballsy!!
Where's your car off to now?
You guys if Chris can give me a date to bring it down - can you go ask him now lol?
haha, lowered it off the tow truck or he climbed up?
Took it off and drove into inspection bay to show that it can be driven, albeit very loudly. Many looks from people before we took it off and even more looks when we started it up lol
  • Like 1
Ain't at work today, am debating whether or not to go to the doctors in an hour that's how much I don't want to move :\
you young people have no apprication of hard work, when I was your age I hade to hop to work in the snow as I could only afford 1 sock per year.
then work 20 hours for 1$ a day (thus the saying of another day another dollar) b4 starting my second job as a moving target for the police force.
and I never called in sick.
amidoingitright?
  • Like 1
amidoingitright?
almost.
Better than being trapped inside...
Must take a look at mine as well... keeps getting stuck halfway down... the bolt that tightens onto the motor shaft keeps working itself free and slipping. Time for some locktight me thinks
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
