I find it a little scary that your life can be messed with, for better or worse, simply because of what a computer screen displays...with very difficult or non-existent avenues for getting it changed. It's not corruption proof, but it's fairly repeal proof.
Reminds me of that movie The Net.
GTR registered
No RWC required
Guy did have a weird look on his face when he walked out to see it on Jack's tow truck. Also saw Russell there coincidentally.
Noice!
stick it to the man, man.
saw a strange car on the road today. an older man, driving a de-badge toyota or some sort... i suspect a AE95 JDM sedan. Stock everything except a towel across the back seats. It was beyond pristine. the rear mud guards were like brand new, the paint put most show'n'shiners to shame. the chrome on the (stock?) dual exhausts looked fresh.
Did someone really do a full restoration on what im pretty sure was a late-80's corolla?
Had classic (not historic) white text on black numberplates. the old skool ones before green.
haha did you pull up in the inspection bay with the car on the tow truck? Did they need to check VIN etc?
Yep
I said it has a bad engine knock and I'm taking it to my mechanic before driving it on the road, which is true. He just confirmed the chassis and engine numbers (spent ages trying to read the RB26 engine number, lulz were had), then we swapped the numberplates over and nek minut registered.
Yep
We have customers who get the works done on their cars, spend big money on it, THEN go to vicroads to get it registered... Very ballsy!!
Where's your car off to now?
You guys if Chris can give me a date to bring it down - can you go ask him now lol?
haha, lowered it off the tow truck or he climbed up?
Took it off and drove into inspection bay to show that it can be driven, albeit very loudly. Many looks from people before we took it off and even more looks when we started it up lol
  • Like 1
Ain't at work today, am debating whether or not to go to the doctors in an hour that's how much I don't want to move :\
you young people have no apprication of hard work, when I was your age I hade to hop to work in the snow as I could only afford 1 sock per year.
then work 20 hours for 1$ a day (thus the saying of another day another dollar) b4 starting my second job as a moving target for the police force.
and I never called in sick.
amidoingitright?
  • Like 1
amidoingitright?
almost.
Better than being trapped inside...
Must take a look at mine as well... keeps getting stuck halfway down... the bolt that tightens onto the motor shaft keeps working itself free and slipping. Time for some locktight me thinks
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
