I find it a little scary that your life can be messed with, for better or worse, simply because of what a computer screen displays...with very difficult or non-existent avenues for getting it changed. It's not corruption proof, but it's fairly repeal proof.
Reminds me of that movie The Net.
GTR registered
No RWC required
Guy did have a weird look on his face when he walked out to see it on Jack's tow truck. Also saw Russell there coincidentally.
Noice!
stick it to the man, man.
saw a strange car on the road today. an older man, driving a de-badge toyota or some sort... i suspect a AE95 JDM sedan. Stock everything except a towel across the back seats. It was beyond pristine. the rear mud guards were like brand new, the paint put most show'n'shiners to shame. the chrome on the (stock?) dual exhausts looked fresh.
Did someone really do a full restoration on what im pretty sure was a late-80's corolla?
Had classic (not historic) white text on black numberplates. the old skool ones before green.
haha did you pull up in the inspection bay with the car on the tow truck? Did they need to check VIN etc?
Yep
I said it has a bad engine knock and I'm taking it to my mechanic before driving it on the road, which is true. He just confirmed the chassis and engine numbers (spent ages trying to read the RB26 engine number, lulz were had), then we swapped the numberplates over and nek minut registered.
Yep
We have customers who get the works done on their cars, spend big money on it, THEN go to vicroads to get it registered... Very ballsy!!
Where's your car off to now?
You guys if Chris can give me a date to bring it down - can you go ask him now lol?
haha, lowered it off the tow truck or he climbed up?
Took it off and drove into inspection bay to show that it can be driven, albeit very loudly. Many looks from people before we took it off and even more looks when we started it up lol
  • Like 1
Ain't at work today, am debating whether or not to go to the doctors in an hour that's how much I don't want to move :\
you young people have no apprication of hard work, when I was your age I hade to hop to work in the snow as I could only afford 1 sock per year.
then work 20 hours for 1$ a day (thus the saying of another day another dollar) b4 starting my second job as a moving target for the police force.
and I never called in sick.
amidoingitright?
  • Like 1
amidoingitright?
almost.
Better than being trapped inside...
Must take a look at mine as well... keeps getting stuck halfway down... the bolt that tightens onto the motor shaft keeps working itself free and slipping. Time for some locktight me thinks
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
